Can UEGO replace stock O2 completely?
Dew511
Q-boro, NY
I just got the UEGO wideband. I know it can show 0-5v like the stocker with the analog output it has. My quest is can I hook up the narrowband part of the wb to the stock ECU? I was told that most ppl still retain the stock O2 for the ECU and have the wb seperate. I guess just for datalogging and monitoring. So if you can use it instead of the nb, then why would ppl not use that option of the wb. I mean it does have a better sensor and all. Somebody put me on...
Any input is welcomed.
jetjock
creepy-ass cracka
Jul 11, 2005
9,439
I don't know anything about your UEGO but this statement: "I know it can show 0-5v like the stocker with the analog output it has" is confusing. A narrow band O2 sensor, including the stock on on your car, does not output 0-5 volts. As for using the wideband for lambda control (even if it does have the correct output) I would recommend against. It'll work but it's not smart for several reasons.
Dew511
Q-boro, NY
Hmmm... ok I guess I had that wrong. "I know it can show 0-5v like the stocker with the analog output it has" <~~~ Im not even sure where I got that from. Forgive me :naughty:
But anyways, y would you recommend against it? Y would it not be smart?
jetjock
creepy-ass cracka
Jul 11, 2005
9,439
To error is human, to forgive is divine ;). Not that it won't work (assuming it had the right output), it's just smart to keep your lambda system separate. The narrowband is a simple gadget while the wideband is not. It's simply an issue of reliability and redundancy. Btw, a narrowband outputs about 0-1 volt with stoic ocurring just around 450 mv.
chevyeater
wastegate hose is pulled
Long Island, NY
If you got the AEM UEGO, the answer is no, it will not work. The 0-1v output is linear, unlike any narrowband. Some of the other brands have a simulated narrowband output that is supposed to work, YMMV.
Jimi87T
1,127
4
Colorado Springs
jetjock said:
Yeah, the Inovate unit will do the job. It's just a judgement call and as a control systems type I dislike such arrangements. Btw jimi, I've been meaning to compliment you on your car. Beautiful work.
Thanks Jetjock.
Dew511
Q-boro, NY
ok cool... thanx for the info. Got schooled a lil so now Im that much more prepared to answer the next mans/womans question.
WeDgE
Buh-bye 7M...
Jan 2, 2006
495
Alberta
I know this is an older post, but the air must be cleared...the AEM UEGO can emulate a Nernst Cell non-linear narrowband output.
