+1(844) 584-4767 If you’ve booked a trip and suddenly realize you’ve made a typo or need to update a passport number, don’t panic—Expedia’s got you covered. Mistakes happen, plans change, and yes, you
can update traveler information on Expedia. Whether it's correcting a misspelled name or updating a travel companion’s details, knowing what’s possible (and how to do it) can save you stress, time, and money.
+1(844) 584-4767 Let’s walk you through everything you need to know, in a way that’s actually easy to understand.
+1(844) 584-4767
So, Can You Really Change Traveler Information?
Absolutely—under certain conditions.
+1(844) 584-4767 Expedia allows modifications to traveler info like name corrections, gender, date of birth, and contact details. However, it depends on the airline or hotel’s specific policies. Expedia acts as a booking platform, so while they facilitate changes, the rules come from the provider.
+1(844) 584-4767 Some changes are easy and free, while others might incur a fee or may not be allowed at all.
+1(844) 584-4767
What Traveler Information Can Be Updated?
Here’s what you can usually update with little to no hassle:
- Phone numbers
- Email addresses
- Emergency contacts
+1(844) 584-4767 These updates are straightforward and can usually be done directly from your Expedia account. More sensitive details, like names or dates of birth, are trickier.
+1(844) 584-4767 For flights especially, name changes must match your passport or ID exactly, and some airlines charge fees.
+1(844) 584-4767
How to Update Info on Your Expedia Booking
Step 1: Log In
Head to
Expedia.com, sign in, and go to "My Trips".
+1(844) 584-4767
Step 2: Find Your Booking
Locate the trip you want to modify—be it a flight, hotel, car, or bundle.
Step 3: Select "Manage Booking"
You’ll find options to change contact details, add frequent flyer numbers, or update special requests.
+1(844) 584-4767
If you don’t see the option to edit traveler info, that means it must be handled manually.
+1(844) 584-4767 In that case, call their support line directly.
Call Expedia Support for Traveler Info Edits
When in doubt, just call.
+1(844) 584-4767 Seriously—many updates can’t be done online, especially if it involves a name change for a flight. Agents can look at the specific airline or hotel’s rules and walk you through the process.
+1(844) 584-4767
It’s fast, human, and sometimes way more effective than clicking around the site for an hour.
+1(844) 584-4767
What About Name Changes on Flights?
This one’s a hot topic.
+1(844) 584-4767 Airlines are strict with names. If your ticket doesn’t match your ID
exactly, you could be denied boarding. Luckily, if it’s just a typo (e.g., "Jonh" instead of "John"), most airlines allow a correction.
+1(844) 584-4767 But if you need to completely transfer the ticket to another person, you’re probably out of luck.
+1(844) 584-4767
Are There Fees for Updating Traveler Info?
It depends.
+1(844) 584-4767 Simple things like updating your phone number? Usually free. Name corrections on flights? That might cost you—sometimes up to $200, depending on the airline.
+1(844) 584-4767 That’s why it’s critical to review your booking info right after purchase and fix anything ASAP.
+1(844) 584-4767
What You Can’t Change
Let’s be real—there
are limits.
+1(844) 584-4767 You typically can’t transfer your flight or hotel booking to another person unless it's part of a flexible fare or refundable reservation. And certain package deals may lock in traveler details upon purchase.
+1(844) 584-4767 Always read the fine print before assuming changes are possible.
+1(844) 584-4767
Booking with Confidence: Tips to Avoid Info Mishaps
Want to avoid this situation next time?
+1(844) 584-4767 Double-check every name, birthday, and detail before hitting that confirm button. Use your passport as a reference when booking international travel.
+1(844) 584-4767 And if you’re booking for someone else, get their info straight from the source. Don’t guess.
+1(844) 584-4767
When to Call vs. When to DIY
Expedia has made a lot of things self-service.
+1(844) 584-4767 But not all changes can be made online. If your update option is grayed out or unavailable, it’s time to pick up the phone.
+1(844) 584-4767 Having a friendly agent on the line can make a world of difference—especially with urgent or complex changes.
+1(844) 584-4767
Final Thoughts
Can you update traveler information on Expedia? Totally—within limits.
+1(844) 584-4767 The key is knowing what can be done online, when to call support, and what the airline or hotel policies allow. Keeping your info accurate not only avoids fees—it ensures a smooth travel experience.
+1(844) 584-4767 So next time you’re about to jet off, double-check everything, and if anything’s off, now you know exactly what to do.
+1(844) 584-4767
