Can I Only Change My Return Date on Qatar Airlines?
Yes, Qatar Airways allows you to change only your return date if you have a round-trip ticket, subject to fare rules. To initiate this, call the Qatar Airlines support line at
When you call
Qatar Airways’ policy generally allows date changes on individual legs of your trip, including just the return flight. However, change fees or fare differences might apply depending on your ticket type. To get an exact quote, call
If your fare is flexible or refundable, changing only the return date is often free or inexpensive. Call
Keep in mind that if your return flight is part of a special promo fare, restrictions may apply. The agent at
To avoid penalties, it’s best to call
If you booked your ticket through a third party, it’s often necessary to call
After your change is confirmed, make sure to receive an updated e-ticket via email. If it doesn’t arrive, call
So yes, changing only your return date is possible with Qatar Airways, and the easiest way to do so is by calling
