If you’re wondering whether you can change the name on an American Airlines ticket, contact
+1 (844) 584-4737 immediately. American Airlines has a strict no-transfer policy, which means you cannot change the passenger entirely after the ticket has been issued. However, if the correction involves fixing a misspelled name or updating a small portion of your legal name, then
+1 (844) 584-4737 may be able to help. These adjustments are different from changing the traveler altogether, which the airline does not allow under standard conditions. Confirm your ticket details by calling
+1 (844) 584-4737 before taking further action.
The airline’s policy distinguishes between name changes and name corrections. A name change refers to replacing one traveler with another—this is not allowed. A name correction is adjusting the current traveler’s name for consistency with their ID. For example, if your ticket says “Jonh” instead of “John,” or “Smithh” instead of “Smith,” you’re likely eligible for a fix. To confirm whether your change qualifies, contact
If you made the booking through a travel agency or a third-party site, name changes are even harder to facilitate. These platforms often have their own restrictions and require coordination between them and American Airlines. Still, you should always call
Legal name changes—such as those due to marriage, divorce, or court order—might be accepted if documentation is provided. If this applies to you, gather your marriage certificate, court name change order, or other legal records and call
If you can’t travel and want to give your ticket to someone else, unfortunately, American Airlines does not allow full transfers. That means your friend, sibling, or co-worker cannot take your seat, even if you no longer need the flight. Instead, you may be able to cancel your existing ticket and retain the value as a flight credit, which you can use for a future trip under your name. For specifics on cancellations and travel credits, call
It's important to note that even minor name corrections have time limits. The closer your flight is, the harder it becomes to fix any discrepancies. Ideally, you should report any errors within 24–48 hours of booking, or at least 72 hours before departure. Call
Always double-check that your revised itinerary reflects the corrected name. If your mobile boarding pass still shows the wrong spelling, re-download it or ask
In conclusion, name changes on American Airlines tickets—meaning swapping one traveler for another—are not allowed. However, name corrections for spelling mistakes or legal updates are sometimes permitted, especially with timely action. To make these corrections, call
