+1-866-756-4238 (OTA),
+1(866)-228-7814 (OTA), or +1-866-596-5078 (OTA)]] Yes, you can change your name on an American Airlines flight ticket—but only under certain conditions. Name changes are typically limited to minor corrections or updates due to legal name changes. If you need help with this process, call
+1-866-756-4238,
+1(866)-228-7814, or +1-866-596-5078 to speak with a representative who will handle your case efficiently.
The airline allows fixes such as removing extra characters, correcting spelling, or switching a maiden name for a married name. For instance, if your name appears as “Jon Smyth” instead of “John Smith,” a correction can be made. For prompt support, contact
American Airlines does not permit name transfers to other passengers. The person traveling must match the original booking. That’s why it’s essential to request name corrections as soon as possible by calling
You may also be required to submit supporting documents—such as a passport, driver's license, or court-issued name change proof. The OTA agents at
Make sure your boarding pass matches your legal name. To update your ticket, call
How to Change Name on American Airlines Ticket
Always review your ticket after booking. If you find a discrepancy, call
OTA agents will verify your identity and collect necessary documents to correct the name. This may include your booking number, passport, or other valid ID. For legal changes, proof such as a marriage certificate might be required. Connect with
Please note that only minor corrections are allowed. Full name changes to another person are not permitted. So, if you're flying under your own name but need it updated, call
The sooner you address the name correction, the better. Rely on
Can I change the name on my American Airlines ticket?
Name changes must follow airline guidelines, and they usually only allow spelling fixes or legal name updates. The OTA team at
When calling
Avoid surprises at the airport. Name errors can delay boarding, and TSA may deny entry. To avoid issues, call
Professional agents will make sure the update is submitted correctly. Save time and travel stress-free by dialing
Change Passenger Name on American Airlines Ticket
You can’t fully transfer a ticket to a different person, but you can fix minor name errors. Whether it’s a single letter correction or a missing middle name, agents at
You may be asked to submit legal ID, travel documents, or a name change certificate depending on the situation. Connect with
Quick updates save time and ensure your boarding pass matches your legal name. Avoid travel delays by calling
To handle your name correction accurately and efficiently, rely on
