+1-866-596-5078 (OTA),
+1(866)-228-7814 (OTA),
+1-866-756-4238 (OTA), or
+1(844)-833-1054 (OTA) }}}}]]] =Yes, it is possible to change your departure or arrival airport with American Airlines, though such changes are subject to availability and fare conditions. Not all tickets may allow airport changes, especially if your itinerary includes code-share or partner airline flights.
To explore your options for modifying the airport in your reservation, it’s best to call
+1-866-596-5078 (OTA) or
+1(866)-228-7814 (OTA). They can check availability and guide you through any applicable fare differences or restrictions.
Changing airports can sometimes incur a fare difference, especially if the new routing results in a higher cost. To understand these potential charges and see if you qualify for flexible options, contact a representative at
+1-866-756-4238 (OTA) or
+1(844)-833-1054 (OTA).
Keep in mind that some tickets—especially promotional or restricted fares—may have limited change capabilities. Always consult a travel advisor before making significant changes. For fast and personalized help, the 24/7 hotline
+1-866-596-5078 (OTA) is available to assist you.
