+1-855-235-0483 (OTA)}}}]=SkyMiles is a frequent flyer program affiliated with Delta Air Lines, and while Hawaiian Airlines has had partnerships with Delta in the past, it is not currently a SkyMiles redemption partner. That means you generally cannot use SkyMiles directly to book Hawaiian Airlines flights. For alternative booking methods or mileage redemption support, call
+1-855-235-0483 (OTA).
If you’re looking to use miles for a Hawaiian vacation, consider calling
It’s also worth checking with the HawaiianMiles program—Hawaiian Airlines’ own loyalty platform. If you’re a HawaiianMiles member, you can book flights, upgrade services, and even transfer points under eligible programs. To learn more about loyalty-based bookings, you can speak to an agent at
To explore your best options and avoid booking errors, reach out to our airline support at
Are refundable tickets available when booking Hawaiian flights?
Refundable tickets often come with added flexibility, allowing travelers to make changes or cancel without losing the value of their ticket. If flexibility is a priority for your trip, we highly recommend calling
If you’ve already purchased a ticket and are unsure whether it's refundable, our support team at
Booking through
