I have an 88 na. I bought a 1jz-gte with a rear sump is there for any reason it wont fit?
zSP3CTERz Member Oct 21, 2008 396 1 18 Chattanooga, Tennessee, United States Apr 6, 2009 #1 I have an 88 na. I bought a 1jz-gte with a rear sump is there for any reason it wont fit?
ronnie4 Member Nov 25, 2007 136 0 16 39 Huntsville Apr 6, 2009 #2 zSP3CTERz;1289928 said: I have an 88 na. I bought a 1jz-gte with a rear sump is there for any reason it wont fit? Click to expand... What motor mounts are you using?
zSP3CTERz Member Oct 21, 2008 396 1 18 Chattanooga, Tennessee, United States Apr 6, 2009 #3 ronnie4;1289957 said: What motor mounts are you using? Click to expand... im using the BIC mounts.....its not the mount problem..i cant get the oil pan to fit past the rubber mounts on the car..
10secdream Got Boost? Sep 11, 2007 767 0 0 38 Edmonton, Alberta, Canada Apr 6, 2009 #4 Are you sure you have a rear sump? Reason I ask is that the motor in your avatar looks to be from a chaser.
marlonvip Supra -only way to fly Sep 2, 2006 189 0 0 Denmark Apr 7, 2009 #5 Yeah think maybe you have a middle sump - show some pics
zSP3CTERz Member Oct 21, 2008 396 1 18 Chattanooga, Tennessee, United States Apr 7, 2009 #6 if you tell me this is anything but a rea sump i will shoot myslef:aigo:
scottiedawg66 New Member Apr 1, 2005 676 0 0 43 Bay Area Ca Apr 7, 2009 #7 post a pic that is not totally useless
tissimo Stock is boring :( Apr 5, 2005 4,238 0 0 41 Melbourne, FL Apr 7, 2009 #8 scottiedawg66;1290523 said: post a pic that is not totally useless Click to expand... Its not, you can clearly see the engine is rear sump. Bolt the mounts to the engine then drop it it.
chuckmuska2005 New Member Dec 3, 2007 265 0 0 39 canton Apr 7, 2009 #9 I had the same issue, I just tilted the engine and shifted it front to back. Went right in.
Poodles I play with fire Jul 22, 2006 16,757 5 0 44 Fort Worth, TX Apr 7, 2009 #10 mounts bolt to the engine to drop it in, not the subframe...
