Can a MKIV RPS be used on a 1J/2J R154 with a 6spd flywheel?
Kruso
2J>7M
Jun 9, 2007
34
SugarLand
I'm wondering if anyone knows the answer to this. I have a RPS stage 3 clutch but its for 6spd and per all the pics I've seen of both the 7M and the 2J just the mounting points on the flywheel look different and *maybe* center diameter. I also have a 6spd flywheel sitting around collecting dust that I could use.
Kruso
tissimo
Stock is boring :(
Melbourne, FL
6spd clutch can only be used with a 6spd trans/flywheel. The input splines are different then a r154, and maybe a different diameter. The 7m/2j flywheels are different sizes too iirc (7m takes a 200mm disc, 2jz takes a 220mm disc)
You maybe able to use a 2jz flywheel with a custom clutch disc (r154 splines), but not sure of fitment inside the R154 bellhousing.
Kruso
2J>7M
Jun 9, 2007
34
SugarLand
Yeah, I know the splines are different between the 6spd and R154. I would look into some sort of a R154 disk with the 6spd clutch.
