Cams
JStoked
646
Edmond, Oklahoma, United States
Ok got the car running. turbo locked up that's all fine have a new one. then taking the elbow of we twisted the top of the down pipe off. OK again that's all fine have a hks 3" on the way. then found a crack in the exhaust manifold so we welded that up. So my question is supposedly this car is a 7mgte with n/a cams. Is this bad to?
carter
"The Ninja"
Nov 1, 2005
743
Ohio
As for it being bad to have na cams, from the info i remember its ok if you wanna hit 350hp or under... If you wanna go anymore then that, might as well keep the turbo cams.
NA cam (singular, since only the intake cam is different) choke the motor at higher RPM's...exactly where the turbo kicks in.
