cam/crank position sensor
ginglesturbo
Boost Nazi
Dec 1, 2007
129
Charlotte N.C.
im down to the last little bit on my hg swap...i took out the cps and didnt mark it. how do i line it back up with tdc? is there marks on it im not seeing? and how do i set the marks?? pics would be nice thanks
Nomad707
Im From The Bay
Mar 14, 2007
1,039
Santa Rosa, California
there is a ton of posts on this... you take the CPS and line it up with the notch in the gear with the notch above the gear.. and insert it while both cams are at TDC and engine is at TDC... lots of posts with pics.
