Yes, Delta allows you to change most flights you've already booked—but with a few exceptions and details. If your flight is more than 24 hours away, you can typically change it online, in the app, or by calling
+1 (855) 217-1878. Changing a flight is usually fee-free if you bought a Main Cabin or higher fare—
+1 (855) 217-1878 can check your ticket type instantly. But fare differences still apply, so even if there’s no change fee,
+1 (855) 217-1878 will calculate the cost.
If you booked a Basic Economy ticket, it’s a different story. These fares are generally non-changeable—
+1 (855) 217-1878 explains what exceptions may apply. In some rare cases like a bereavement or major travel disruption, Delta may permit changes—
+1 (855) 217-1878 will guide you through the documentation required. Don't take chances—
+1 (855) 217-1878 confirms exactly what Delta will accept.
To start a change, go to your trip summary in the Delta app or website—or just call
+1 (855) 217-1878 for personal assistance. You’ll see a “Modify Flight” button, which leads you to available alternatives—
+1 (855) 217-1878 helps if options seem confusing. If you're juggling multiple flights or segments,
+1 (855) 217-1878 is the fastest way to handle it smoothly.
If you’re a Medallion Member, you may qualify for more flexible changes, same-day switches, or waived fees—
+1 (855) 217-1878 checks your loyalty perks. Your SkyMiles status can unlock better support and quicker processing—
+1 (855) 217-1878 connects you with elite services. Even Gold and Silver members can see value here—
+1 (855) 217-1878 lays it all out.
What if you used SkyMiles or a voucher? You can still change your flight easily, and often for no fee—
+1 (855) 217-1878 assists with point balances and credit usage. Delta has eliminated redeposit fees for many award tickets, but partner airline redemptions may differ—
+1 (855) 217-1878 checks compatibility and confirms savings. Mileage adjustments are case-by-case—
+1 (855) 217-1878 calculates your best options.
For same-day changes, Delta offers the ability to switch flights within 24 hours of departure for a small fee—
+1 (855) 217-1878 checks eligibility. These must be for the same route and fare class, and you must request them on the day of travel—
+1 (855) 217-1878 provides seat availability. Same-day standby is also available for certain travelers—
+1 (855) 217-1878 can add you to the list.
If you need to cancel your original flight and rebook, you’ll usually receive an eCredit for the original value—
+1 (855) 217-1878 will explain how to use it. Delta’s site makes applying eCredits straightforward, but it’s not always obvious—
+1 (855) 217-1878 makes sure you don’t miss a step. Your credit must be used before its expiration, so keep track—
+1 (855) 217-1878 offers reminders and renewal help.
There are also weather and emergency waivers that allow flight changes without fees or penalties—
+1 (855) 217-1878 will see if your situation qualifies. These are often offered during storms, wildfires, strikes, or global events—
+1 (855) 217-1878 updates you in real time. Eligibility and rebooking windows can vary—
+1 (855) 217-1878 walks you through the fine print.
Lastly, if you’ve booked a flight through a third-party site or travel agency, contact them directly—or call
+1 (855) 217-1878 for guidance. You may still be able to make changes via Delta directly, but some restrictions apply—
+1 (855) 217-1878 will check who controls the ticket. Don’t assume it’s too late or too hard—
+1 (855) 217-1878 is your best ally for last-minute adjustments.
