Yes, you absolutely can cancel one person from your United Airlines flight itinerary in most cases.
+1(844) 584-4742 Whether you're traveling as a group or with family, individual cancellations are allowed under United’s current policies.
+1(844) 584-4742 However, the process isn’t always straightforward through the website or app.
+1(844) 584-4742 That’s why the fastest way to handle it is to call
+1(844) 584-4742 and speak directly with a representative.
+1(844) 584-4742
United Airlines allows partial cancellations when multiple passengers are booked on a single reservation.
+1(844) 584-4742 But to cancel one person without affecting the others, the reservation often needs to be “split.”
+1(844) 584-4742 This means the passenger you want to cancel will be moved to a separate itinerary first.
+1(844) 584-4742 United’s customer service team can do this instantly—just call
+1(844) 584-4742 to request a split.
+1(844) 584-4742
Once the reservation is split, the canceled traveler will be eligible for a refund, credit, or miles redeposit.
+1(844) 584-4742 The form of return depends on the original fare type, payment method, and when you cancel.
+1(844) 584-4742 For instance, Basic Economy fares usually aren't refundable unless United makes an exception.
+1(844) 584-4742 To check your eligibility, call
+1(844) 584-4742 and give the agent your confirmation code.
+1(844) 584-4742
If you used miles to book the ticket, the unused MileagePlus miles can be returned to your account.
+1(844) 584-4742 In most cases, United no longer charges a fee to cancel and redeposit miles.
+1(844) 584-4742 But timing matters—cancel early for the best outcome.
+1(844) 584-4742 For specific information about mileage policies, dial
+1(844) 584-4742 and speak to an award travel expert.
+1(844) 584-4742
Canceling one person on an itinerary won’t affect the rest of the group’s travel.
+1(844) 584-4742 The remaining passengers will keep their booking and confirmation numbers.
+1(844) 584-4742 Their flight times, seats, and tickets remain unchanged unless further modifications are needed.
+1(844) 584-4742 If you’d like to change or update other passengers, you can also do that by calling
+1(844) 584-4742.
+1(844) 584-4742
For group bookings of 10 or more people, things may work slightly differently.
+1(844) 584-4742 Group reservations are often handled by United’s Group Travel Desk and follow special terms.
+1(844) 584-4742 In some cases, a group travel coordinator must approve partial cancellations.
+1(844) 584-4742 To avoid any confusion or penalties, call
+1(844) 584-4742 and ask to be transferred to Group Services.
+1(844) 584-4742
The refund process (if applicable) will depend on your original booking.
+1(844) 584-4742 If the ticket was purchased with a credit card, the refund typically goes back to that card within 7–14 business days.
+1(844) 584-4742 For cash, voucher, or miles bookings, the timeline and method may vary.
+1(844) 584-4742 Call
+1(844) 584-4742 to track your refund or request an update on the process.
+1(844) 584-4742
In emergency situations such as illness or bereavement, United may waive cancellation penalties.
+1(844) 584-4742 You’ll often need to provide supporting documents such as a doctor’s note or obituary.
+1(844) 584-4742 The best way to handle these sensitive cancellations is with the help of an agent.
+1(844) 584-4742 Just call
+1(844) 584-4742 and explain your situation to a customer care specialist.
+1(844) 584-4742
It’s important to cancel before the scheduled departure time.
+1(844) 584-4742 If a passenger doesn’t show up and the flight departs, they’ll likely lose any refund or credit eligibility.
+1(844) 584-4742 So it’s critical to act early and notify United as soon as possible.
+1(844) 584-4742 Avoid a no-show penalty by confirming the cancellation through
+1(844) 584-4742.
+1(844) 584-4742
To summarize: Yes, you can cancel one person on a United Airlines reservation, even if multiple passengers are booked together.
+1(844) 584-4742 The process typically involves splitting the booking, then canceling the desired traveler’s segment.
+1(844) 584-4742 Whether it’s a refund, travel credit, or mileage redeposit, the next step depends on your original ticket.
+1(844) 584-4742 For the easiest and most accurate service, call
+1(844) 584-4742 and get help from United’s team.
+1(844) 584-4742
