Broken oil pump drive pulley, help
Nick Squire
80
Montreal, Quebec, Canada
Hey guys,
The end of last year my oil pump drive pulley snapped off, today I finished opening up my 7m to check whats going on, nothing seems seized, I can turn the engine over just fine by hand, I can also turn the oil pump shaft without a problem. If anyone has had a similar problem or knows what happened it would be great to find out, my teacher took a look and isn't sure either. I know that Beech performance has their retention plate that they sell but my plate looks fine and fully intact, so I don't see what went wrong.
This is the pulley hanging where it should be, you can see its broken and quite a bit of metal was sheered away
This is the inner section of the pulley
Piratetip
Far From Maddening Crowds
1,179
69
MKE, WI
Take some macro photos of the spokes and center.
Will be pretty easy to determine failure mode.
Likely cyclic stress crack propagation.
Nick Squire
80
Thanks guys! I read almost everything you guys posted and I'm in the midst of checking if a friend of mine can get the older style pulley for me, if not then I'll get the new one and be sure to be extra careful installing it!
