boost leak???
Godspeed
88 supra turbo 5spd
May 13, 2005
1,119
Asheville n.c.
ok my 1g runs stock 10psi well i was driving it the other day i noticed when i get on it it would run up to about 9-9.5 and then fall back to like7.5 or so what the hell???? i checked all piping and hose but they are all tight any other things i should check?
i also found a used single setup for my car its a to4e coldside 60 trim and hot side 57 trim the single mani. and all oil lines and an hks external gate. for about $300 dollars i know its worth it but do you think it would be a good size turbo to run on this engine?
7MGTEsup
Formerly 'Down but not out'
Jun 14, 2005
614
England
Sounds like your wastegate diaphram might be starting to go south. Or there might be a small crack in one of your hoses that only opens up under boost.
