Hey peoples,
I have had an oil leak in the spark plug valley and recently swapped the centre valley gasket with four o-rings on the 14mm hex bolts...didnt see a point in spending $100AU for that piece of whatever it is....:icon_bigg
Ive managed to stop the oil leak from there BUT there is still some oil appearing after a little spirited driving...:3d_frown:
I have a feeling its not coming from the rocker seals or those 14mm bolts mentioned above, so does anyone know what the 14mm hex bolts (exactly the same as the ones mentioned above) in between the spark plugs are and whether I can take them out and see if there the problem?? You can just see the 3 of them in between the spark plugs in the picture....
