Blown Head Gasket After Effects (Sludge)
chris89
419
Columbia, MO
Ok, so recently i got a blown head gasket and when my mechanic pulled the head and checked the coolant passages, He reported sludge like gew in the passages... How can the block be Cleaned spotless? Is this normal? I'm guessing that's what happens when oil combines with coolant? I just want some good helpful advice so i can get my baby back together. Running safely and reliably. THANKS
cuel
1,536
Baytown, Texas
That's also what happens to a poorly maintained coolant system. Bet you've been adding water for a while. I took out the plug for the coolant drain in the block(mid way down block, around cyl.6, exhaust side), and hosed it out with a high pressure nozzle. Started at the front of the block, and worked my way back through every coolant port in the block deck. Mine wasn't really bad, but there was some rust, scaling, and block seal in there. Went back and forth until only clean water ran out. That was 2 years ago, plus. Changed the water pump today, and flushed out the cooling system while I was there. Nothing but clean water and coolant came out.
The BEST way, is to pull the block, strip it down, and take it to a machine shop and have it cleaned there. They can stick it in a hot tank, and it'll come out looking almost new.
cuel
1,536
Baytown, Texas
Should. Would really depend on what you're trying to remove. I'm not really sure how well it would work on hard deposits and scaling. Ask your teacher, he should know, or just give it a try. Any cleaning is better than none at all.
