Blown Freeze Plug
Heatmiser
24
Nashville
My first question is - can the wrong radiator cap (MKIV Turbo) on a MKIII cause enough increased pressure to cause a freeze plug blow?
I have searched and have found some good info so far, I just blew the freeze plug right near the turbo - My car sat for about four years before I bought it and then completely rebuilt the motor ( I have upgraded the turbo, injectors, exhaust etc... - I have replaced just about everything else as well... including all the coolant hoses..
Since it's been cold and since I've been running the heater is it possible I could've blown some crap loose from the heater core and caused a clog somewhere?
Before the freeze plug blew - it was running good and temp was fine - I'm running about 15 psi on the turbo.
I will get the toyota freeze plug to be sure and double check the two small coolant hoses as well...
Any other ideas?
Thanks in advance...
tlo86
Ninja Editor 'Since 05'
Jul 24, 2005
3,914
Colorado
i will say no to the radiator cap... i wouldnt see why it would make a difference
Jason T
JZS161 Aristo TT
Auckland New Zealand..Aotearoa
http://http://www.absoluteradiator.com/Radcap.htm
Increasing your cooling system pressure by installing a radiator cap that has a pressure rating higher than factory specs increases stress on the entire system. Although some race cars use high pressure caps, their cooling systems are built to handle these higher pressures
. We recommend that you only use a cap with the pressure rating that your car was designed for.
starscream5000
Senior VIP Member
Aug 23, 2006
6,359
Hot and Humid, KY
Since it was rebuilt right before you got it (so says you), I'd hazard a guess and say the new freeze plugs were standard sized and not metric like they were supposed to be, hence them blowing. ;)
