I was wondering if there was any way to check the adjustment of the hot/col blend door and where i would find it? I was unable to locate anything about the heater or climate control system in the car in the TSRM and i searched all over this website and got nothing useful. Today i was driving around a lot and noticed with the fan on ac off and temp set to 65, warm air was blowing out the vents, warmer than outside it seemed. Normally my AC works very cold on the freeway, but today ac temps were significantly higher. It was blowing cool, but definitely not cold. When i turned the heater on, it definitely did get hotter, but it still seemed too hot with the heater off. I took a look at the valve in the engine bay, and something confused me. I thought when the "arm" was up, the valve was open. With the fan on ac off, temp at 65, i was getting warm air, the "arm" on the valve was up. I pulled the vacuum line off momentarily and the "arm" dropped down, suddenly i am getting burning hot temps out of the vents, put the vac line back on, cycled the temp up to 85 and back to 65, and was warm again and "arm" was up. Pulled vac line again and once again hot temps out of the inside vents.
I thought if anything, it should be opposite. I was under the impression that with the "arm" down, the valve was closed and shouldn't allow any cooling, but this is also irrelevant. With the climate control set to 65, shouldn't my blend door be keeping the hot air from entering my cabin in the first place? Is there any way to access this or at least test its functionality? Thanks.
