bhg maybe?
MKTURBO3
93
NEWYORK
so everytime i start up my car in the moring i get the waterfall sound. i do have alot of white smoke coming out but i always think cause of the cold weather. i do not over heat i have no mily stuff under the oil cap or in my resivoir tank. i do have a small leak of coolant somewhere just couldnt have much time to find it. should i be worry i loss coolant little by little. im on a rebuilt motor with cometic mhg arp studs 80lbs torqued.
tlo86
Ninja Editor 'Since 05'
Jul 24, 2005
3,914
Colorado
i would drain some of your rad you will see oil in it or your oil and you will see coolant in it :)
ImpulseDrive
123
Brooklyn
Since there is a thread with this title I'll post here as well.
My car has begun to overheat on me but seems only when the boost is used. I'm using factory stock psi and never modified it with a MBC or anything.
I had the factory hg changed over a year and a half ago but it was for yet another factory hg replacement. I changed the thermostat and fan clutch with new ones. The water pump is fine and I have no leaks of anti freeze, the back up tank is also full. When I start the car it has white smoke like the OP said but I figured like him, it was the cold weather. I also checked my oil but it doesn't seem milky, a solid black color, no white residue.
I really don't want to accept its a broken head gasket although I'm starting to tell myself it is and my current one will give out any day now. Is there ANY other possibility or something I overlooked that can be causing my sudden overheats during long driving and sudden boosting? I take the precaution and grandpa drive my car now to prevent any damage to my engine since my supra is also my daily, but the needle seems just a LITTLE above normal towards the hot side and it bugs me a bit.
Thanks in advanced.
87M-GTE
Slow
Sep 12, 2007
1,705
Milwaukee WI
If you start it and blast the heat is it warm or cool? Check the coolant overflow tank, sometimes that gets low and would cause you to have no heat.
sneakypete
Regular Member
Jul 18, 2007
1,129
Central NJ
Thanks in advanced.
If your oil is solid black, you should change oil. It shouldnt be that dark. If there is coolant in your oil, you'll see it when you drain your oil. And the same when you drain your coolant, you will see oil floating on top.
Another thing you could check is if the airflow to the radiator might be blocked with leaves. When i installed a new radiator, the old one was clogged up with leaves and feathers. i had no idea until i removed it from the car... check that out
-pete
ImpulseDrive
123
Brooklyn
Yeah this week is my scheduled oil change week. (Tomorrow to be exact) I will look at the drained oil to see if there is coolant mixed but I didn't see any oil when the coolant was drained before we installed the fan clutch. so I'm assuming the head gasket is still working but it's worn and about to break if I was to put the car on the highway constantly with extended boost.
As for the leaves in the radiator, never thought of that, although its worth a look, hardly any trees in new york though lol. Thanks for the tip!
