Best Penis Extender is Found: My Real 9-Month Test~9 Devices Reviewed
powerdude
Best Penis Extender: My Real 9-Month Test With 9 Devices​
I never imagined I’d become the kind of guy who buys every major penis extender on the market just to test them. But here I am, 9 months and thousands of hours of traction therapy later, finally ready to share the results.
My mission? To find the best penis extender — based on real use, real effort, and real goals.
I tested each device for a month, using it daily for 1 to 3 hours, following manufacturer instructions exactly. I also added jelqing to support results. After trying all 9, I stuck with the one that worked best and used it for a full year.
Quick Rating — Line-by-Line (Out of 5 Stars)​
  • Quick Extender Pro: ⭐⭐⭐⭐⭐ (5/5)
  • Phallosan Forte: ⭐⭐⭐⭐✩ (4.5/5)
  • Penimaster PRO: ⭐⭐⭐⭐✩ (4.5/5)
  • SizeGenetics: ⭐⭐⭐⭐ (4/5)
  • ProExtender: ⭐⭐⭐ (3/5)
  • Total Man System: ⭐⭐⭐ (3/5)
  • Jes Extender: ⭐⭐⭐ (3/5)
  • Penimaster Chrome: ⭐⭐✩ (2.5/5)
  • Male Edge: ⭐⭐ (2/5)
Why I Did This Crazy Test​
I was tired of reading marketing hype. I wanted to see which extender was comfortable, effective, and worth the money. I spent hundreds of dollars and months of dedication to finally reach my conclusion.
The Best Extender I Tried: Quick Extender Pro
https://geni.us/qep20
Used for: 6 months straight after my initial test
⭐ Overall Rating: 5/5​
This was the most comfortable, adjustable, and results-driven device I tried. It uses DSS (Double Strap Support) technology, which really helped lock in the right tension. It was easy to wear for longer sessions (2-3 hours), didn’t cause circulation issues, and came with a full routine and accessories.
✅ Pros:​
  • Double strap feels secure and distributes pressure
  • Lightweight rod-based frame
  • Easily adjustable for tension and length
  • Comes in several packages (Value, Deluxe Standard, Deluxe Limited, Peyronie’s)
  • Strong traction up to 4000g
❌ Cons:​
  • Some learning curve on initial setup
  • You need to measure yourself properly before ordering
Packages:​
  • Value Edition: Basics
  • Deluxe Standard: Includes comfort pads and extra rods
  • Deluxe Limited: Full kit with carrying case, rods, pads, DVD, etc.
  • Peyronie’s & Curvature: Designed for men with curvature issues
Buy here: https://geni.us/qep20
My Weekly Experience With Quick Extender Pro​
Week 1: A bit tricky to set up at first. I had to watch the tutorial twice.
Week 2: I found the right length and started wearing it 2 hours a day.
Week 3: Jelqing + extender routine started feeling smooth. Less fatigue.
Week 4: Noticed a fuller flaccid hang. Comfortable wearing during work-from-home.
Weeks 5–8: Upgraded to 3 hours/day, began tracking stretch gains.
Month 3 Onwards: Skin got used to the pressure. Gains were visible on ruler.
After 6 Months: Gained about 1.9 inches in length. Best decision I made.
Phallosan Forte​
https://geni.us/phallosan
Overall Rating: 4.5/5
A vacuum-based device that wraps around the glans with a soft suction bell and uses a belt to pull. Very stealthy for day use.
✅ Pros:​
  • Super discreet under clothing
  • Works while sleeping
  • No rod or base ring
❌ Cons:​
  • Less customizable tension than rods
  • Condoms/sleeves wear out fast
Packages:​
  • Classic: Basic belt system
  • PLUS+: Adds rod-based module
  • Combi: Includes belt + rod combo
  • Knee Belt: Alternative traction path
Penimaster PRO​
https://geni.us/penimaster
The most medically complex system I tried. Suction adhesion + diaphragm creates a strong hold. Multiple options: rod, belt, weight.
✅ Pros:​
  • Versatile packages
  • Ultra secure head chamber
  • Excellent for Peyronie’s
❌ Cons:​
  • Takes time to master vacuum system
  • Not great for quick on/off
Packages:​
  • Rod Extender
  • Belt Extender
  • Weight Extender
  • Complete Set (best value)
SizeGenetics​
https://www.goforsize.com/go/sizegenetics
Rating: 4/5
A very reputable rod extender. Comfortable enough, but not my favorite in terms of adjustment.
✅ Pros:​
  • Proven results
  • Foam padding included
  • Includes traction plan
❌ Cons:​
  • Not as stable during movement
  • Mid-range tension
ProExtender​
https://www.goforsize.com/go/proextender
Rating: 3/5
One of the original extenders. Budget-friendly, but dated.
✅ Pros:​
  • Affordable
  • Simple mechanics
❌ Cons:​
  • Less comfortable
  • Fewer adjustment options
Total Man System​
https://geni.us/totalman
Rating: 3/5
Mix of hanging, pumping, and traction. Overwhelming for beginners.
Jes Extender​
https://www.goforsize.com/go/jes-extender
Rating: 3/5
Popular in the past, but doesn’t match modern designs.
Penimaster Chrome​
https://geni.us/penimaster-chrome
Rating: 2.5/5
Heavy and metallic. Cool to look at, hard to wear.
Male Edge​
https://www.goforsize.com/go/maleedge
Rating: 2/5
Bright plastic and aggressive marketing. I found it flimsy and hard to trust for tension.
Rod vs. Vacuum Extenders​
Rod Extenders (like Quick Extender Pro, SizeGenetics):
  • Offer precise mechanical tension
  • Better for long sessions
  • Require break-in period
Vacuum Extenders (like Phallosan, Penimaster PRO):
  • Use suction to hold the head
  • More discreet
  • May have sleeve wear or slippage
Which One Should You Buy?​
If you're new: Quick Extender Pro or Phallosan Forte If you want full control: Quick Extender Pro with Deluxe package If you want vacuum style: Penimaster PRO complete set If you’re on a budget: ProExtender
My favorite: https://geni.us/qep20
Final Thoughts​
After trying all 9, I went with Quick Extender Pro for my full routine. It was the best mix of comfort, results, price, and science. I now recommend it to friends and readers who want serious gains without surgery or hype.
Note: Always consult your doctor before using any medical device.
BlakeR
13
ProExtender is a non-surgical traction device designed to gently stretch the penile tissue by applying gradual tension. The kit includes a base ring, adjustable rods, silicone straps, and cushioned contact points. It’s worn for several hours daily and supports trunk lengthening, girth improvement, and curvature correction (common in Peyronie’s disease).
proextender-box-unpacked
Secure your deal today—authentic products only on the ProExtender Website
Effectiveness​
Clinical and user data suggest it can yield moderate gains—typically 1 to 2 inches in length—after consistent use spanning several months. Some users also report thicker erections and firmer tissue. The gains tend to be permanent as long as you maintain your usage regimen.
User Experience​
  • Positive stories:
    • Many report measurable length increases after 4–6 months.
    • Some saw curvature improvements and better overall erections.
    • Users describe enhanced stamina and confidence.
  • Mixed or negative outcomes:
    • A subset reports discomfort, redness, mild bruising, or even minor pain.
    • A drop-out rate of ~20-30% is common, often due to soreness or lack of visible results.
    • Occasional build complaints cite plastic components that can wear or break, and customer support can be slow.
Time Commitment & Side Effects​
Expect to wear it for 4–6 hours daily, sometimes split across sessions. Initial weeks may bring tightness or awkwardness. Typical temporary side effects include:
  • Skin irritation or soreness
  • Minimal bruising or redness
  • Temporary numbness if tension is excessive
Following instructions, including taking breaks and avoiding excessive tension, helps minimize discomfort.
Cost & Support​
Priced moderately (approximately $150–300), it's far more affordable than surgical alternatives. However, replaceable parts may incur extra costs, and user feedback on the responsiveness of customer support is mixed.
✅ Pros & Cons​
Pros
  • Non-invasive; no surgery or recovery time needed
  • Clinically studied; reasonable length gains observed
  • Can improve curvature in Peyronie’s cases
  • Potential boost in erection firmness and sexual confidence
Cons
  • Requires patience and discipline over many months
  • Discomfort and minor side effects during adjustment
  • Variable build quality; fragile plastic pieces reported
  • Results vary significantly—some users see little change
Who It’s Best For​
  • Ideal if you’re seeking a non-surgical way to enhance penile length or treat mild curvature.
  • Suitable for those willing to commit long-term and tolerate mild discomfort.
  • Not recommended if you want fast results, have a low discomfort threshold, or prefer minimal daily hassle.
Final Take​
ProExtender stands out as one of the most studied and reputable penile extenders available. It offers a plausible, non-invasive pathway to lengthening and curvature correction. Success hinges on consistent, disciplined use and realistic expectations.
If you’re considering it:
  • Follow usage guidelines closely
  • Start slow, increase tension gradually
  • Monitor your body’s signals—stop if you feel numbness or coldness
BlakeR
13
Effectiveness​
User Experience​
  • Positive stories:
Cost & Support​
✅ Pros & Cons​
Pros
Cons
Who It’s Best For​
Final Take​
