Battery Question
killarb634
Jersey's here
Ok wierd problem. I had a red top optima battery in my car for over a year and had all kinds of silly problems. The battery would keep dying on me and i would have to jump the car about once a month. Checked everything and couldn't figure it out. Brought the battery back to the store to get tested. kept telling me no problems with it... about the fourth time i brought it back they tested it and said the battery was defective... They replaced it for free. New optima red top. same problem. Took an everready battery and put it in the car had it in for over a month No problems. question
Has anyone had problems with the optima batteries?
killarb634
Jersey's here
tested at 14.2 volts...
edit
car runs fine with no problems. Car ran fine while running just battery never held a charge. both of them. This battery is fine..
vdragonmpc
tireflaminrumpshaker
Apr 11, 2005
300
Colonial Heights
www.joncjennings.com
YES!
I have had issues with Optima batteries in several cars. The main issue is that the dropouts working at the auto parts stores dont know what the hell they are doing (thats why you have to bring your part with you as they will 80% of the time sell you the wrong part and convince you its the right part)
What happens is they dont notice that an Optima is a gel-cell battery. It has to be charged at 2 amps NOT on a fast charge that kills the battery. What happens is they charge it and sell it to you basically damaged.
I had the jackass at the Advance in Colonial Heights VA detonate my battery in the charger (it had been ok both times it left me sitting) then he notices that he doesnt HAVE ANY IN STOCK! Joy. I had to go to Petersburg to get a replacement.
With other folks what has happened over time is they seem to change shape and are not dependable. You arm your alarm and in the morning its dead. kaput. If you want you can even buy an optima knock off at Merchants... Looks exactly the same. I mainly bought it for the stereo but there are better options and the warranty isnt what it used to be..
V
killarb634
Jersey's here
Yeah I thought it was my alarm.. Thought i screwed up wiring my stereo... couldn't figure it out. even with the new one. i put this battery in and no probs. It really annoyed the shit outta me after i'd set all my radio stations and come back and they were gone i was pissed.
supraman7mgte
Shut up,bitch!!
Sunny California
Same problem here.I too have a red top,and have to keep it on a charger sometimes.I took it back to Sears,they basically charged it and load tested it and it came back okay.It has been working fine for the past 4 days now. I might upgrade to a yellow top.
vdragonmpc
Apr 11, 2005
300
Colonial Heights
I had to play the 'its ok' game with my battery. After the 3rd time that it died and I had to jump it I told them either replace it or give me a porta-charger.
They tried to blame my alternator BUT I have an external regulator that shows field and charge... I also have access to a snap-on tester that loads the alternator. The alternator, grounds and everything else was fine. I took the battery to my blazer and it died there too. Of course then they blew it up at the store...
V
