Battery Cable Routing
Warpath
Help me Jeebus!!
Oct 28, 2008
135
St.Louis
sneakypete;1296754 said:
mkiii222 just answered your question.... very simple
Not trying to be difficult or ask stupid questions I just want
To make sure I'm doing it right & there's no other place. Some of the
cars that worked on in the past the cables went to a starting solenoid
And such. Plus I'm old and having a hard time following the routing diagrams
LOL. I know too that your not giving me a hard time & I appreciate mkiii222
Info very much.
-jim
sneakypete
Regular Member
Jul 18, 2007
1,129
Central NJ
sorry if i came out harsh but the wiring is pretty straight forward and you should have no problem with it.
just make sure you dont mix up the positive and negative... ive done that before with a new set of wires from toyota
Warpath
Help me Jeebus!!
Oct 28, 2008
135
St.Louis
You didn't & thanks for the help!
-jim
mkiii222
Troy, MI
And such.
I did forget about this one.
So:
2 Negative, One to the fender next to the battery, one to the block behind the a/c compressor
2 Positive, One to the fuse box, one to the starter
That's all that goes to the battery unless you have an aftermarket audio system or have wired up your own relays for something else.
Warpath
Help me Jeebus!!
Oct 28, 2008
135
St.Louis
So:
Awesome! Thanks for the help!!
mkiii222
Troy, MI
GeneStarWindGSW;1297808 said:
Yea im want to relocate my battery to the trunk. Any safety precautions i should take? Also how about relocating fusebox?
Battery: Use at least 4 gauge wire and put it in a sealed/vented enclosure.
Fusebox: Just leave all wiring routed the same. Use the same gauge wire and totally replace the wire if you have to extend anything, don't leave splices mid-wire as they'll just be weak points later.
