I had my battery charged because it was dead, now is pulling 12+ volts. I hooked the positive and negative cables up and immediately checked the volts with a multimeter and almost instantly they're at around 8V and dropping rapidly. After removing the cables off the battery it starts returning to the higher volts. Only thing I've done electrically recently was pull the radio out to get to where an oil pressure gauge was wired. There was a very thin ground coming out that I had to remove and screw down again but I even tried unplugging the radio altogether and that didn't change anything.
So would a bad battery act that way or do I need to go on a parasite hunt now?
