auto tranny from a supra/soarer on a 1jz what parts do i need for it???info...
toyota88
104
horst
auto tranny from a supra/soarer on a 1jz what parts do i need for it???info...:1zhelp:
I want to use a auto tranny on a 1jz.
I have one auto tranny from a 7MGTE and also i have the one from the soarer 1jzgte.
Wich one is the best option to use?
I geuss the one from the 7MGTE type 30-40LE
What parts do i need to get it working on the 1jz??
bell house? where to buy?Can i use the bell house from the 1jz?
Flexplate??
Torx converter??
i would also like some info to get it working.
please need some info
Beals
JZA70 TT-R
Feb 3, 2009
591
Alberta, Canada
the bellhousing is only going to work for the one from the soarer (1jz) other then that everything should just bolt up. you can always put a different stall converter on it though depending on what you're using it for.
toyota88
104
horst
thanx for the info.
1j bell house will directly fit.great!
butt i also heard that a 3j bell house will work whith some modification.
butt i will use the one from the soarer then.
