Article: The Toyota Common part number sticky
MDCmotorsports
Indy 500
www.MDCmotorsports.com
Im thinking of some of the more common parts we all buy for our cars and the part number for them so in case you HAVE to order them from a dealer/parts group by part number you can.
I'll throw out some common parts, and you guys throw out the part numbers.
-Green truck shifter bushing
-Plastic bushing on the end of the shifter nose
-Coil pack harness for the 7mGTE
-Rubber / Neoprene hose that connects the valve cover to block
-Parking brake pads
19518-42020 Coil pack harness for the 7mGTE
12263-42010 Rubber / Neoprene hose that connects the valve cover to block
Parking Brake
46540-14020 Front Parking Brake Shoe (RH or LH) (Qty: 2)
46590-14020 Left Rear Parking Brake Shoe (Qty: 1)
46550-14020 Right Rear Parking Brake Shoe (Qty: 1)
Targa
63251-14061 Front targa seal
63252-14032 Rear targa seal:
62383-14052 Pass side targa seal
62384-14052 Driver side targa seal
09169-14010 Targa tool handle
09168-14010 Targa hex bit
09120-14011 Targa toolbag
63296-14010 Cap, removable roof, front
63297-14010 Cap, removable roof, rear
Lock bezel clips
90468-04124 RH Bezel "Offset" Clip
90468-04126 LH Bezel "Offset" Clip
90468-04125 RH and LH Bezel "Straight" Clip
Wiper inserts
85221-YZZB1 Front LH (85221-YTCB1 - Canada)
85221-YZZA9 Front RH (85221-YTCA9 - Canada)
85221-YZZA9 Rear 86.5-88 (85221-YTCA9 - Canada)
85221-YZZC8 Rear 89-92 (85221-YTCC8 - Canada)
Wiper blades
85220-16540 Front LH (86.5-88)
85220-1A020 Front LH (89-92)
85220-3A050 Front RH
85220-32120 Rear (86.5-88)
85220-16441 Rear (89-92)
Wiper arms
85190-14630 Front LH (86.5-88)
85190-14700 Front LH (89-92)
85210-14250 Front RH (86.5-88)
85210-14270 Front RH (89-92)
85190-14680 Rear (86.5-88 N/A)
85190-14690 Rear (87-88 Turbo)
85190-14731 Rear (89-92)
Wiper blade to arm screws
90099-00955 Front (Qty: 4 -- 2 per side)
90099-00913 Rear (Qty: 2)
Fan Shrouds
16711-42010 Main shroud (86.5-88)
16711-42060 Main shroud (89-92)
16702-42010 Lower (No.2) shroud
Fan Clutch
16210-42040 N/A (86.5-88)
16210-42060 N/A (89-92)
16210-42050 Turbo (87-88)
16210-42070 Turbo (89-92)
Tail Light Gaskets
81554-14580 Both Sides (86.5-88) (Qty: 2)
81554-14580 RH Side (89-92)
81564-14610 LH Side (89-92)
Trunk Weatherstripping
67881-14110
Trunk Rubber Stops
90541-09047
Turbo Accordian Hose (AFM to Turbo Housing)
17882-42012
Special Clamps
82710-24010 Brown diag box Engine wire clamp (special order from Japan only)
82711-30070 Black intake runner Engine wire clamp
Under Hood Rubber & Gaskets
15100-42031 7M-GE Oil Pump
15100-42021 7M-GTE Oil Pump
13568-49015 Timing belt
90507-18008 Tensioner spring for timing belt
90916-02364 Power Steering Belt
99365-21290 Water Pump & Alternator Belt (Includes Fan)
99364-20920 Air Conditioner Belt
Starter Overhaul Parts
28226-72080 86.5-90 Battery Side Terminal Kit
28226-72010 86.5-90 Motor Side Terminal Kit
28226-76070 91-92 Battery Side Terminal Kit
28226-74070 91-92 Motor Side Terminal Kit
Engine rebuild / block part numbers
13411-42030 86.5-89 Crankshaft (6M Crankshaft)
13411-42040 90-92 Crankshaft ("7M" Crankshaft)
13612-42020 Oil Pump Drive Shaft
11022-41010 Oil Pump Shaft Bearing Set
90387-26001 Oil Pump Shaft Collar
13011-42060 7M-GE Piston Ring Set (Std Size)
13013-42060 7M-GE Piston Ring Set (0.5mm Oversized)
13011-42011 7M-GTE Piston Ring Set (Std Size)
13013-42012 7M-GTE Piston Ring Set (0.5mm Oversized)
11071-43010-XX No.1 Main Bearing (Qty: 1, Std Size, XX = Size Code)
11701-43010-XX No.2 Main Bearings (Qty: 6, Std Size, XX = Size Code)
11704-43010 Main Bearing Set (0.25mm Undersized, Complete Set)
13041-42010-XX Rod Bearings (Qty: 6, Std Size, XX = Size Code)
13204-42010 Rod Bearing Set (0.25mm Undersized, Complete Set)
11011-43010 Crankshaft Thrust Washer Set (Std Size)
11012-43010 Crankshaft Thrust Washer Set (0.125mm Oversized)
13101-42070-XX 7M-GE Pistons (Qty: 6, Std Size, XX = Size Code)
13103-42070 7M-GE Pistons (Qty: 6, 0.5mm Oversized)
13101-42080-XX 7M-GTE Pistons (Qty: 6, Std Size, XX = Size Code)
13103-42080 7M-GTE Pistons (Qty: 6, 0.5mm Oversized)
96412-43500 Front Frost Plug (Qty: 1, Behind Timing Cover)
96411-44000 Side Frost Plugs (Qty: 7)
96411-43500 Rear Frost Plug (Qty: 1)
Engine
11101-42030 Cylinder Head
11400-42081 86.5-89 7M-GE Short Block (6M Crankshaft)
11400-42140 90-92 7M-GE Short Block ("7M" Crankshaft)
11400-42101 87-89 7M-GTE Short Block (6M Crankshaft)
11400-42102 90-92 7M-GTE Short Block ("7M" Crankshaft)
11401-49596 7M-GE Bare Block
11401-49606 7M-GTE Bare Block
90099-14088 Cam Position Sensor O-Ring
90250-08120 dowel pin for block
22278-42010 Idle Speed Control Gasket (to surge tank)
25628-42020 EGR flange gasket #1(surge)
25627-42030 EGR flange gasket #2 (head)
22271-42040 gasket for throttle body to surge tank
13568-49015 timing belt
13505-42020 timing belt idler pulley
90311-42003 oil pump drive shaft oil seal
90311-52003 crankshaft front oil seal
90311-35017 camshaft oil seal (Qty: 2)
Auto Trans parts
83710-14700 Cable assy, speedo
83770-22120 Adaptor assy, speedo
5-speed conversion for the pressure plate assy.
31231-14040 Hub, clutch release
90201-71001 Washer, plate
90206-72001 Washer, wave
90520-67001 Ring, shaft snap
31264-14040 Spring, clutch
90201-45023 Washer, plate
31470-14050 Cylinder assy, clutch
96152-00450 Ring, snap
28100-45050-84 Starter, reman exhange
90363-12002-77 Bearing, ball (Pilot bearing?)
90363-45012 Bearing, ball. (Throwout bearing?)
R154
33348-35010 R154 1st gear thrustwasher
3110114010 R154 inspection cover
3110214010 R154 inspection cover
3314630020 R154 deflector
Manual Transmission Shifter Parts (R154 & W58)
33505-35020 Shifter Pivot Seat/Bushing (Truck/4Runner Part) - Green in Illustration
33548-31010 Shifter End Bushing - Blue in Illustration
33555-22050 Lower Rubber Shift Boot
33584-22020 Shifter to Transmission Gasket - Red in Illustration
93381-16012 Shifter to Transmission Bolts (Qty: 4)
Fuel Tank
77169-14020 Gasket, Fuel Sender Gage
77169-14010 Gasket, Fuel Pump Bracket
Engine Air Hoses
17348-42010 Hose, Air, #2 (For Idle Speed Control Valve)
17342-42040 Hose, Auxiliary Air Valve, #2 (CBV)
12262-42010 pcv hose to TB
12261-42010 pcv hose to cam cover
12264-42010 Hose, Ventilation, #4 (PCV)
Engine Cooling
16571-42010 Upper Radiator Hose
16572-42020 7M-GE Lower Radiator Hose
16572-42010 7M-GTE Lower Radiator Hose
16401-63010 86.5-92 7M-GE Radiator Cap
16401-63010 87-89 7M-GTE Radiator Cap (Larger Style)
16401-72090 90-92 7M-GTE Radiator Cap (Smaller Style)
90916-03078 Thermostat
16341-35010 Thermostat Gasket
89422-20010 EFI Water Temperature Sensoe
Turbo
04111-42021 Complete turbo gasket kit
15471-58010 turbo to turbo oil pipe gasket
15473-42010 turbo Oil Outlet gasket #2 to block
16347-42020 turbo to no.1 & no.2 water pipe gasket
90430-12005 Gasket For Turbo Oil Inlet Pipe to block (2)
90430-14235 turbo no.2 coolant pipe to water outlet housing union gaskets (2)
96721-19010 o ring for dipstick
Throttle Position Sensor:
89452-20050 - 01/86 to 10/86 7M-GE (RPL 89452-28030)
89452-14050 - 11/86 to 04/93 7M-GE
89452-20050 - 08/86 to 02/89 7M-GTE (RPL 89452-28030)
89452-14050 - 03/89 to 04/93 7M-GTE
89452-22080 - 1JZ-GTE
Exterior
75331-14120-01 Black 91+ Toyota "T" emblem (Only colour available)
81521-14332 Euro half amber half clear front turn signal
81511-14332 Euro half amber half clear front turn signal
steveaw11
116
georgia
Not listed up there but for the Fuel Tank, the filler neck to tank gasket is the same as the pump bracket to tank gasket.
So order 2 of those if your getting them, they are dirt cheap.
toyotanos
What will we break today?
2,844
Coon Rapids, MN
MK4 motor mounts for round mount replacement. *Will require grinding/removal of the large locating 'nub'
Insulator Assy, Engine P/N 12360-46011 (get 2)
They look extremely strong compared to the round mounts and they are very much cheaper! (About 2/5 price)
Edit: after running these on the street- I can't really tell if they are any more harsh than the originals, plus they didn't break.
Jamie-B
10
NSW
Does anybody have part number for Oil pressure gauge sender in 7mge?
And the MK3 non turbo diff seal?
rfurgy
73
Franksville, WI
If you want a short throw shifter, all you need to do is remove the large extender. It was glued on in my car and with some of the strongest glue I've encountered. Heat from a small torch should speed up removing it but only if you pull the shifter first and are careful not to scorch anything else in the process. Did it to mine and the shifter fits perfect into the console. It doesn't have any threads on it but if you're creative you should be able to figure out how to get a knob on there.
FlawLessHOVA
MA
Is it large enough to use a chaser to create new threads for a shift knob????
charman02
Cruiser
Oct 14, 2008
121
Fresno
So does these part number only work for Toyota dealership? Or does it work every where else? I tried part number search on champion Toyota website, alot of them like the transmission stuff shows no result and with rock auto, it doesn't work at all. Any ideas?
warlock415
california
good reference, just a question, i have a problem with my 86 ma70, the shifter it is all over the place, its kinda difficult to know which gear i am at, the shifter part you published, will it be the same for my car? thanks
BOOSTEDSUPRA
THE DRIVELINE GUY
Jan 4, 2007
308
turlock, calif
these are toyota part numbers only. doubt theyll work for anyone elses place.
Dtr89mk3
Maryland
I work for a Toyota dealer in Md. I'd be more than happy to help find parts and or part numbers. I have noticed while trying to "Restore" my car a lot of these parts are no longer available.
