Anyone Replace a window motor?
Steve_N
Louisville KY
The TSRM only shows how to take the entire door apart. I don't want to do that. Just want to know how to get at the motor w/o removing the glass & regulator assy. Anyone have advice on what/Not to do when replacing it. I have the door panel off but I don'e see how to get at the motor. :1zhelp:
TIA
NashMan
WTF did he just wright ?
Aug 5, 2005
4,940
17
Victoria BC
dude doing is veray easy some times you don't have to replace the motor any way most of the time the magnets will fall off in said the can re gule them back on and poof the thign works again may sound getto but that how they were put on in the frist place
i have yet to see motor stop be cause it was fired or bush's were dead
oh yae the wind reg is held on but 10 mill bolts get buddy ot help you by holdong the window weil you pop the motor out
and if remmber right you might bebale to get the can off with removeingt eh window or window reg
Steve_N
Louisville KY
Thanks for the info guys. Are there any small parts such as guides or adjusters that I should replace with new while I have things apart? The window was kinda squeally when it was going up/down. Also how hard is it getting the glass lined back up after its reinstalled?
Thanks again
88MK3
117
Phoenix,AZ
It mad a screeching sound before but not since put some grease on the tracks. My advice is to have a 2nd person help u. I did it my self but was a pain
88supraTT
292
around the bend
not really sure but is kinda the same area.my window goes up and right before it gets to were it needs to be its just starts makeing a "poping" noise and moves up and down any thoughts?i think i may have to adjust the track or somthing but any info would be nice.
thanks
