anyone heard anything about ebay full gasket sets?
xDBOYx
49
Jersey Shore
im in the process of ordering a gasket set for my other motor so i can reassemble it and i heard that people have used ebay gasket and say they work well.. has anyone used or heard anything about them? this is what i found on ebay let me know which one is better and which is best for the buck. or should i get toyota gasket set ?
http://cgi.ebay.com/ebaymotors/87-9...ewItemQQcategoryZ33665QQitemZ8071746116QQrdZ1
http://cgi.ebay.com/ebaymotors/Full...ewItemQQcategoryZ33620QQitemZ8070710593QQrdZ1
http://cgi.ebay.com/ebaymotors/Toyo...ewItemQQcategoryZ33667QQitemZ8070793321QQrdZ1
http://cgi.ebay.com/ebaymotors/FULL...ewItemQQcategoryZ33667QQitemZ8071069632QQrdZ1
http://cgi.ebay.com/ebaymotors/TOYO...ewItemQQcategoryZ33667QQitemZ8072531455QQrdZ1
http://cgi.ebay.com/ebaymotors/87-9...ewItemQQcategoryZ33665QQitemZ8073464298QQrdZ1
which one would you suggest for the bang for the bucks
brad92t
186
Lexington, KY
www.haxors.us
From http://supraforums.com/forum/showthread.php?t=294702&highlight=gasket
Adjuster said:
...BTW, I'll never buy a gasket kit again. Waste of money.
All you need are the cam seals, front and rear main seals and the oil pump drive seal. The only cut gaskets you need are the exhasust and intake manifold ones. EVERYTHING else can be done with "the right stuff" or similar sealer. (And if you use sealant everywhere a gasket went, you will never, ever have an oil or coolant leak at those points. Ever.) I've also used the sealant to make sure the TB does not leak, no problems yet, just don't use very much of it. (Thin is good when you have a close, flat metal to metal seal.)
he is also on this site, so he may chime in here and nail it home :)
johnathan1
Supra =
Aug 19, 2005
5,056
I got the eBay set for like $75, and it was alright...the only problems that I saw were that the TB gasket was waaaay too small, I had to modify it, and the exhaust gaskets are absolute crap, as is the head gasket (duh) and the cam seals didn't fit.
Does anyone else advocate using no solid gaskets, just silicone? That kinda bothers me...can this be done?
brad92t
186
Lexington, KY
www.haxors.us
sorry i screwed that link up.. i edited my original post..
my block is currently apart, and i plan on putting it together with The Right Stuff when it comes back from machine shop, whenever that may be.. i do enjoy saving $200... i think The Right Stuff is like 11 bucks a can or something... :)
