Anybody with a UK spec 7M?
Inygknok
Tropical Paradise
Sep 22, 2005
488
Puerto Rico
I really, really, really need someone with a UK spec 7M to answer some quick questions. If you have one, and any kind of camera, I'd like you to please take a shot of the following item:
http://www.cygnusx1.net/Supra/Library/EPC/291220/catalog.aspx?F=7701&P=3
To be specific, the check valve labeled 77701T and what seems to be a filter labeled 77268 and if it really just ends there. That's what I need shots of. Really appreciate whomever helps out with this!
ValgeKotkas
2,224
Over the pond
I think Euro spec is fine enough;)
I can take pics of the 77701T ( though it looks just like the one in the EPC :D), too bad that the hose after it is hanging loose :/
Inygknok
Tropical Paradise
Sep 22, 2005
488
Puerto Rico
It should look just like the one in the EPC :p, but I want to completely compare it to the other one I have here. Mine should be smaller. I also want to know if there's anything special about it visually that I can't tell from just the drawing.
Still, I'd like to ask you. The hose after the check valve, it just ends there? As in, it vents out into the air?
Kai
That Limey Bastard
UK spec is different in some ways don't forget. And what you ask inygknok is a MASSIVE ballache to do, just for a photo. It might be worthwhile to ask Stuey (supradupra.com) for his photo's, as he did a detailed photo set of eveyr part that came off, was restored and reinstalled - in order to get under there on my car (even if i hadn't got a busted back or ankle), would take over 2 hours - something thats a little outta the 'do it for a favour' league!
91Supra313
1,062
Clarksville TN
I didn't know there was a difference in fuel tanks and fuel lines and stuff like that between any of the MK3s. Or am I just a retard in thinking that this has anything to do about fuel.....
Inygknok
Tropical Paradise
Sep 22, 2005
488
Puerto Rico
So is there an actual difference in the fuel tank?
Kai
That Limey Bastard
The tanks are the same - the line routing is mostly the same, barring the whole 'vent to atmosphere' deal. Ours are the closest to JDM spec than USDM spec, although we never got toys like TEMS or a Targa roof option. (Pointless in our climate!)
