any one get these codes with maftpro
lian
58
ottawa
21 22 24 32 34 I have been getting these codes and only see these under boost.
For 34 and the boost cut I have been getting at 12 to 13 pounds I have pressure checked turbo to the end of the ic pipe before the throttle body.
Is there a way to pressure test the intake to the head?
I cant seem to hit 15 psi and it use to be able to hit 17 18 and am wondering if these other codes can make the car hit fc.
thanks for any tips and info.
Any
lian
58
ottawa
Ok I fix the fuel cut afjusting the f out max but the one problem im having is the afr is going to 8.1 instead of the nice 11.5 .can anyone help it doesnt look like full throttle tech helps anymore
