everytime EVERytime i unlock my driver the alarm goes off okay No problem ill jsuut unlock the pass door works fine!! i want this problem Solved without disableing the alarm system
I took the door panel off and i notice a green wire hanging around the back of the lock cylinder [which is held in place by one 1 10mm bolt]
there are 3 different types of wires there all green with a different stripe color. You can unclip the whole thing off from behind the lock cylinder
is this wire the reason why the alarm goes off when i unlock the door???
hopefully i can go to the junkyard and find another cuz i can't splice the wire back in
