Im trying to sort out some electrical problems that I wont go into here, just focusing on the alternator ground.
With the car off, alternator out and battery unplugged;
Using my multimeter set to continuity, I touch the ground plug at the Alt. and any ground (negative bat cable, ground under the fuse box, next to the fuse, etc). The digital readout shows .456 or around that, .4xx and the multimeter does not buzz.
If I test from the alternator ground plug to the Alt. fuse, the readout doesnt change and it buzzes.
Going from the Alt. fuse to any ground point, it again reads .4xx and does not buzz.
Everything else Ive tested using continuity, the mulitmeter always buzzes and the readout doesnt change. Is something wrong with my Alt. ground after the fuse or is that normal behavior when testing the continuity there?
If what Im doing even makes sense, Im trying to learn lol.
