Alcohol injection questions
Cya
628
Columbia, S.C>
1.Can the injector be installed before the blow off valve or just after.
2.How far away from the throttle body does the injector need to be fitted for proper atomization.
need new tires
rubber slinger
Nov 10, 2005
173
Dayton,Ohio
well for a single nozzel setup you want it about 6-8 inches from the TB.
i would suggest after the BOV. also if you are using speed density put the nozzel 6 inches before the IAT sensor.
