airbag- quick question need help
keshigomu
9
california
hello, my supra is not registered at the moment due to needing a brake and light inspection, so i need an airbag. i was wondering if it is safe to put in another airbag into the car after the previous one went off and if so do i also need to replace the airbag box under the arm rest console?
8,897
If the car was hit and deployed the airbag, the sensors need to be changed. They are one time use. After the circuit is normal according to tests in the repair manual, then you can put in a new one. The battery should be disconnected during this whole process.
