Aftermarket cams questions.
gixxer750
2jzget comingsoon!
Mississippi
ok, I've got the cams in my head and shimmed.
Mainly, just one question, or a few...
1. Does 8.6 mm of lift turn the motor into an interference motor with stock spacing between the block and head?
2. How many people have properly tuned the BC cams... what is the best degree setting for them from the stock setting... is it 220 @ .050 base they list or off of that?
gixxer750
2jzget comingsoon!
Mississippi
Some complaints about the cams...
1.. not enough assembly lube for everything
2. You can't tighten the nuts on the headstuds with these cams in, because some of the cast in parts are larger, and a socket won't clear. Mainly the second and fourth nut back on the intake side.
MassSupra89
Almost done.
Nov 3, 2005
1,707
MA
The assembly lube ripped open in my box and i got one cam covered in it and none of its usable, had to buy my own.
MassSupra89
Almost done.
Nov 3, 2005
1,707
MA
Tiny container from what I remember. I think it was one of those little things that model paint come in, probably about 2 ounces.
gofastgeorge
944
Texas
There is an extensive thread in the 7M-GE section on the BC low-buck cams, and problems associated with them.
Things such as the timing gear on the ex. cam being out of sinc.,
and bearing journals varying from one end of the cam to the other.
And if you really want to see some BC horror stories,
go by some of the Nissan & Honda forums.
