Something else to keep in mind...the line from the rail to the AFPR to the tank is the return
AN-6 is plenty big enough for this task without causing a restriction...the AFPR
is the restriction (that's where you get the desired pressure).
If you want additional volume to the rail from the tank, it's a different line...the one that attaches to the FPD at the top rear of the fuel rail.
