Aem v1 and rc 550 injectors,
Quazaky
21
Toronto
Im going to go get my car tuned next week i have lex afm rc550s and a aem v1 ecu, the rc550 are low impedence injectors and my research is showing me that i need to trick the aem ecu to think they are high impedance by adding resistors? CAN ANYONE shed some light on this? part numbers, locations, links everything helps want this to go/work smooth as possible. thanks
7m has a injector resistor box already wired in essentially making the low imp injectors high imp. So your fine as long as that's not bypassed.
A v1 is pretty old school as well.
Quazaky
21
Toronto
got the v1 for a good price, so i wont need to wire in any other resistors? I haven't removed the stock one if there is one.
toyotanos
What will we break today?
2,844
Coon Rapids, MN
The resistors aren't there to trick anything in the computer, it exists to protect the drivers within the ECU. Make absolutely certain that there is a resistor in-line with the injectors or you will destroy your AEM and be very sad.
7MGTEsup
Formerly 'Down but not out'
Jun 14, 2005
614
England
toyotanos;2076089 said:
Yup, even if you rewire the harness for sequential injection. Been there, done that!
I'm assuming you used two resistor blocks to go sequential?
Nope. The resistor goes on the power side.
Sequential only requires changing the grounds. Which is basically 3 wires.
