I'm in need of a base map, the one I got from drift motion had an issue as my brother uploaded a 2j map over it.  Any help please email me at rhoads.Christopher.r@gmail.com
			Dingoboy;2034518 said:I have a Driftmotion AEM V2 sitting in a box, waiting to be installed right now. I haven't yet powered it up, but I could give it 12 volts & plug a laptop in to copy the map & send it to you if you like. Will e-mail you as well.
matthunter1448;2088261 said:i need a base to start from on this somehow the one from drift motion was deleted Matthunter1448@yahoo.com
Any more info on which firmware is correct? I may have accidentally done the same thing.seoul4korea;2091875 said:Do you still need one? I figured out my issue. I got mine from driftmotion but I updated the firmware. When I did this it fucked up how the ECU would take the tune. Went back to the old firmware and uploaded it and it's good to go again.
Press22;2094773 said:Any more info on which firmware is correct? I may have accidentally done the same thing.
Need base map also. My email is ipress22@gmail.com
it would be awesome if you could send me a base map I'm new the any form of tuning but took a lightly used aem v2 6050 Honda box with harness from driftmotion as a trade for an engine as the kid blew his 7mgte needless to say one look i knew the fuel map was shit and i wont start my car on said calibrations as i don't want to blow my engine up as well any help would be awesome currently fresh rebuild stock injectors 2.5in fmic from driftmotion 3in divorced downpipe areomotive fuel pressure regulator set to 38psi at idle with vac line hooked up stock ct26 but i will be changing it on Monday for an unknow sized ct comp ball bearing turbo/boss series jr turbine housing for factory manifold but if you send me a stock setup or a 550cc setup I'm sure i can make it work cant be worse then what was on it
