AC piece behind glovebox? And how to remove a sticker on body
89Turbo
804
Portland
i've removed all my AC stuff but i've heard that there is another piece behind the glovebox, what does it look like or what # is it on here:
http://www.cygnusx1.net/supra/library/EPC/MKIII_NATO/291410/index_electrical.html
when i first got my car i joined a buddies car club and put one of there stickers on my drivers side rear quarter panel and now i want it gone, do i use sandpaper then just fix it up with paint?
i do realize how lame these questions are but whatever.
KeithH
Portland, OR
You could use sandpaper and then repaint but that is sort of like using a nuke to clear your land before building a house.
Is the sticker just vinyl? If it is just a sticker you could just try peeling it off and then get some 3M Adhesive Remover to clean up the gunk. A hair dryer will help as you can heat up the glue when you remove it.
Silvasoup
143
Florida
I think you are refering to the evaporator (88501) unit which is behind the glovebox area. I believe it is number 8714 (parts group) in your link that you show. I know that piece all too well as that sob evaporator has had to be replaced several times during the life of my car.:rolleyes:
Silvasoup
143
Florida
Yellow 13 said:
Behind the Glovebox is the fans/blowers/heater core. You can take them out but youll lose your heater.
Yes that unit is there too, but also the evaporator which you don't need if you take out the A/C system.
