ABS light on
mecevans
1,295
M-bay, cali
my abs sensor has been on ever since the GE-auto to GE-manual swap. i never wired in the neutral switch, it just started with no issues and without the clutch needing to be depressed. it turns on after 15 feet of driving and never turns off. under hard braking the driver side front tire locks up first.
mecevans
1,295
M-bay, cali
no engine codes at all. just and ABS light. what diagrams??????? im going off the troubleshooting chart. tsrm say to check the speed sensor due to code 4 and 5 and NO B codes.
TSRM
"inspection of speed sensor
check that there is continuity between A and B four times per each revolution of the shaft. if continuity is not as specified, replace the sensor"
mecevans
1,295
M-bay, cali
yes i checked for ABS CODES. i get ABS CODES...TYPE A 4 & 5, TYPE B no codes.
tsrm
" if there is no indication code for type B perform diagnosis and inspection (see page BE-55)"
did anyone READ MY POST?
jetjock
creepy-ass cracka
Jul 11, 2005
9,439
Appears he didn't ;)
I'm trying to help you but I don't have much time. I'm not supposed to be here and come midnight I go back to being a pumpkin. If the cluster sensor wasn't working you'd get an engine code so it appears yours is OK. And when I said "diags" I meant the cruise control diagnostics. They provide a quick way of testing the cluster sensor...
mecevans
1,295
M-bay, cali
yes i did perform the diagnostics i gave you the diagnostic codes that im getting. im really confused now. if my cluster sensor is working and i get these codes what should i be doing?
what do i check next?
mecevans
1,295
M-bay, cali
ok heres my question....... if the w58 is from a non abs car and i put it in an abs car theres nothing i can do to fix it correct? i would need an ABS w58 and motor harness?
IF the sensor rotor is in the tranny, you could just pop the freeze plug off that blocks the location of the rear speed sensor.
Gotten conflicting info on if they put the rotor in all the trannies or not...
mecevans
1,295
M-bay, cali
my new motor and transmission are non-ABS though, so even if i get the sensor i have to change out the damn harness cause there is not abs plugs on it.
damn
mecevans
1,295
M-bay, cali
Poodles;1436083 said:
Plug should be on the harness still...
thanks for the help and sorry for the confusion.
so i need to go to a yard and find a sup with ABS and get the sensor off the trans? install it in mine then there should be a plug and ill be golden?
IF the sensor rotor is in the trans, if not you either need to add it to yours (open it up, dunno how difficult) or replace the tranny.
