So I'm cleaning out the engine bay, going to do some work to it while I await the Probe pistons.
That said, what kind of trouble am I going to run into, if I unscrew the brake lines from the ABS actuator? I'm certain I'll need to bleed the system, but will it need to be pressure bled, or can my trusty hose-in-a-bottle do the trick?
I want to just move that out of the way, to clean behind it...
