Ok all, Ive talked about this a few times in Earlier threads and I dont want to bring a Old thread back to life so Im just going to shoot you all a problem and I wanna know if Im looking in the right or wrong Direction.
Since I went from a ct26 Based setup to a V-Band flange setup I have had nothing but trouble with my Wideband A/F ratios. Mornings Im Idling at 15.7and by the time I get to work which is only 10 Miles or so, My A/F ratio at Idle is 13.1 to 13.5, Under load or normal driving condition when I first start off in the morning its 14.4 to 14.7 but starts to drop in the rich area the farther I drive. this afternoon when I drove home It wouldnt get out of the 11.0 range and that is just normal cruising.
Everything is set of my VPC to 0 (12 Oclock) and everything on my SAFC is at 0 across the RPM band. Only way I can get it to go back to 14.7 when driving is to put the Low throttle settings on -33% at the 2000 and 3000 RPM range and turn the VPC Idle bottom to -14 on the lean side.
The only thing that I can remember changing when I went to this type setup is from a Factory O2 Sensor to a Aftermarket Ford Mustang 3 Wire sensor. Its the one that people on here recommended. Once I did that is when Ive started having these problem and nothing I have done has changed anything. Could it be the Aftermarket O2 sensor causing this. If so, Is there another type O2 sensor that I can purchase other than this one. Ive bought another one and another Wideband sensor and no Change when they were installed.
Please someone let me know if I might be on to something here. Frustration is starting to really set in to the point that I want to just sell and get out of Supras all together.
Thank you for your time and for reading this.
Robert
Robert
