Hey everyone. I am almost done figuring out the wiring on the cut harness I received. Could anyone tell me what the following wires go to? Much appreciated!
According to the diagrams, this is the dash ground and ecu ground on the M1 connector:
These three brown wires match the M1 dash ground wire. One of these brown wires goes to a ground on the harness and the others splice into some ECU wires. Does this mean that all three of these brown wires will get soldered to the M1 connector brown wire?
This wire (Grey) is labled IGSW Ignition AM2 on connector T pin 13 for the 1JZ ECU. It splits off into two wires that end around the body plugs. Any idea where these are suppose to go?
