I just got my 2j car back on the road (sent the aem back to get the idle circuit fixed) and its hotter then hell so I charged my a/c as well. I originally wired my Fans (dual fal fans) to turn on when the a/c high pressure switch is flipped, then was going to wire a 2nd fan (stock condenser fan) to run when the a/c is on. I haven't wired in the stock condenser fan yet so I just set my aem to turn my fans on Anytime the engine is running.
So A/c works perfect blows cold.. But then I shut off my car. My fans continue to run while the car is off.. Sometimes as much as 2-3 minutes afterwards then eventually shut off. I'm assuming its the A/C High pressure switch thats keeping them on. (Keep in mind my car is wired like the factory Fans as far as the a/c high pressure switch) So I was looking over the factory wiring diagrams and it seems that it gets the power from the Gauge fuse. Now is the Gauge fuse ran off the Key (ignition switch) or is it ran off the main relay. I doubt the main relay is staying on (can verify, but didn't think about it until I started making the post).
Oh and a bit of ranting..
So I just get the aem back, I pulled out my spec stage3+ clutch that the disc is going bad and put in my old spec stg 3 clutch. The car is running awesome, I can actually shift easily (old clutch disc was staying partially ingauged making it a PITA to shift). The 2j runs so much smoother and better then my 7m pos
. And today after I fix my a/c and get it running good.. My f'in twins start to smoke! I dont even have my boost controller on.. its only running like 14 psi.. WTF..ARRGG! I have another set of twins so thats not a huge deal, but I MIGHT have to repull the trans at least to lean the engine forward enough to get the rear twin off, but probably will have to pull the engine to get enough room to pull it. UHHHG! when will I get some better luck
And a few random pics.. I need a paintjob so bad
gay macco paint flaking off
