91 headlights staying on...
sluggo42
151
Socal
Seems like my headlights stay on more and more often now, instead of turning off autoomatically, so I have to shut them off manually.
Is there a switch or button switch somewhere?
Thanks in advance guys,
Doug
sluggo42
151
Socal
jetjock said:
Not turning off autoomatically how? You mean if they're left on and the door is opened?
YES exactly! Normally, I just leave them on all the time and when I turn the car off and get out, they turn off automatically. Now they stay on more often then not, so I have to turn them off with the switch.
jetjock
creepy-ass cracka
Jul 11, 2005
9,439
Auto light off is handled by Integration Relay #2 otherwise it's a simple circuit. Start with the driver's door switch although if the interior lights are behaving the door switch is OK. Maybe a problem in junction block #1 which is in the center block in the driver's foot well. Make sure the block's mounting bolt is tight because it's an important ground.
You don't need to be an electrician. Bottom line is for the system to work power on IR #2 pin 4 must not be present when ground appears on pin 15 (door open).
