87mkIII stock gauges?!?
macharyfro
Grand Rapids
Hello, I have a 87 supra, this winter I will be doing a swap to a 2jzgte and Im wondering if the gauges will work the same? I hope they do but if anyone has info that would be great so I dont f somethin up. Id like to get aftermarket gauges but Id like to try and keep the stock gauges.
Thanks Macharyfro
tissimo
Stock is boring :(
Melbourne, FL
Thanks Macharyfro
They'll work, you just need an adapter for the oil pressure. Everything else will work as it should (assuming you have a turbo tach).
tlo86
Ninja Editor 'Since 05'
Jul 24, 2005
3,914
Colorado
i bought the signal converter for the RPM, whats the alternative?
as for the adapter he means the 7M sensor with fittings from the 2jz to the 7m sensor (you can either use the actual fittings+line from driftmotion i think i used a male oil fitting and a aftermarket braided clutch line as well on the other cars i worked on)
