87 supra w/ problems
NTRA08
TWINKY
Jun 10, 2008
530
Conroe, Texas
I have a 1987 supra. I declare it as a piece of shyt. But its mine... Anyway my car started to studder like it wasn't getting enough fuel. I would spray some throttle body cleaner through and acces. outlet in my ic pipe. and it would clear up. Then it would be fine until I gave it gas. When I held it at any rpm it would clear up. It did that for a while. But now no matter what I do the car seems to sound the same. I cleaned the injectors. installed a aeromotive fpr. Changed the exhaust manifold gasket. I had a very bad leak. finished that and its still the same. I had the car running and i took each wire off one at a time to see if its getting spark. I know its kinda stupid. every cylinder was getting spark but it wasn't all even. ????. I have no clue anymore. I have some mods done to the car also. But I never had any problem with them. the motor has about 12000 miles on it. I just need some helpful advice. i'm lost. all thoughts are welcome
pogoism9
1UZ for me!
May 18, 2007
367
fredericksburg, va
Just to be on the safe side -
Check your compression
Check your fuel pressure
NTRA08
TWINKY
Jun 10, 2008
530
Conroe, Texas
I've got 35-40 psi on the fuel. And I haven't checked the compression yet. I know its low cause of the gasket I have on there. 2.0mm greddy. I need to go to orielys and get a compression tester.
NTRA08
TWINKY
Jun 10, 2008
530
Conroe, Texas
Shaeff. I really didn't do anything to the car. It just happened. I know that it ran real good for a while until one day ran the tank on empty then it acted up again.
