87 and late 89 motor mounts
jeddyminit
66
San Diego 858
I'm doing an 87 turbo swap into a later 89 n/a.
which motor mounts will i need? 87 or late 89.
from my understanding the late 89 mount is the one i need but mounted on the 87 motor mount bracket.
can someone help me out?
any help is appreciated.
Thanks,
Jeddyminit
Jeff Lange
Administrator
4,919
5
Sunnyvale, CA
jefflange.ca
You need the late 89 mounts on the late 89 brackets.
Everything should match the crossmember that is in the car you are trying to put the motor into. Nothing should be mix/matched.
Jeff
