7mgte wire harness 5spd
oheylnaishca
12
Texas
does anyone know where i can find a wire harness for my engine cause mine is already brittle and some of it is broken especiall for the coil pack and the cps..well all of it...
boosted2085
I was spoolin :(
Mar 1, 2009
218
houston,tx
your in tx so call champion toyota in houston they can order one for you...someone on here was selling one on the fs threads..but youll be spending a good penny for a brand new one
boosted2085
I was spoolin :(
Mar 1, 2009
218
houston,tx
Jeff Lange;1415526 said:
Also, it's worth every penny.
Jeff
x2
Unless your an expert at making a harness plus trying to locate perfect clips to every sensor etc,even used harnesses arent perfect and sometimes you still pay a good amount for them,the new harness is well worth it
suprarx7nut
YotaMD.com author
Nov 10, 2006
3,811
Arizona
www.supramania.com
As I recall Dr. Tweak is a member here and he redoes harnesses and from what I recall, he does excellent work.
Might be a good option if you dont want to spend the full 700 or however much the new toyota one is.
Jeff Lange
Administrator
4,926
Sunnyvale, CA
jefflange.ca
Depending on what you need Dr. Tweak to do, the price may not be that much better. If you get one from Champion or Elmhurst, it's probably quite a bit less than $700.
Jeff
