7mgte Tps Voltage Output Needed
Overboostin007
australia
Hey guys i am after the voltage output on the throttle positioning sensor on the 7mgte. I have worked out both wires on the tps harness side and my larger ford 3 inch throttle body that has three wires. But however the voltage outputs are somewhat of a difference some i need to put some resistors in place. I just need to know
Voltage output on the tps plug harness side?
And ohm's output on the tps itself. (at closed and open throttle).
If anyone could help me it would be great.
New engine and i have a problem wiring it up.
Thanks in advance
